robjacobsen
The Pros From Dover
I'm probably spreading rumors, but I've heard rumors that the Grass Valley track is building tire walls and needs help. If you want to help build the tire walls that may make or break your weekend out there next year, I would suggest contacting Bill Murray or Mark Hanken. Power tools and generators are a must for this work. Large holes must be drilled into the sidewalls of the tires so they don't become a mesquito breeding ground and then they must be bolted together in whatever configuration they have chosen to use. It sounds like some folks will be working out there most of the weekends between now and the end of October. Got some time and want to help? Give them a call or drop them an email.
