Fully Prepared Pro 3 spec Race Car #217 based on 1987 BMW 325i
Seat:
Sparco
Multi pane rear view mirror
Suspension:
Ground Control Double adjustable shocks ( damping/ compression)
Ground Control front camber plates
Ground Control rear shock mounts
Eibach ERS race springs 650 front, 800 rear
Adjustable rear camber plates
Adjustable front camber on shock towers
Competition bushings and engine mounts
Ireland Engineering hollow front sway bar
AKG rear tie down hooks installed
corner weighted and balanced
Engine:
Freshly rebuilt ( 3 hours ago) top end
Oil pan baffle to avoid oil starvation
New clutch
New Master cylinder less than 5 hours operating time ago.
Adjustable fuel pressure gauge and pressure regulator
Flex lite cooling fan direct wired to switch in dash
Exhaust
Headers
Ireland Eng Shorty headers
Race exhaust with Magna flow muffler -2” diameter
Differential:
4.10:1 with limited slip differential
Ireland Engineering red race subframe mounts
Cooling fins installed on differential for cooling of dif fluid
Transmission:
AKG short shift transmission
AKG competition transmission mounts
Brakes:
Brake duct cooling hoses
Brembo brakes with competition pads all round
MISC:
Lightweight plexiglass rear and rear quarter windows
Trailer tiedown points on front and rear of car
AMB transponder hardwired in
Data and Communications:
AIM MXL with GPS tracking , oil pressure warning, oil temp warning, shift warning, water temp warning, Alt warning
Radio harness and antennae ( radios not included)
Analog oil temp, pressure and water temp gauges
Safety:
6 point Full Nascar cage with foot protection by DGE Motorsports, Vancouver, Washington
Fire suppression system
Scroth Hans compatible 6pnt harness ( good until )
CACC and ICSCC compliant electrical cut off system and secured lightweight battery
Clear film on headlights
Stainless steel brake lines
Safety Solutions central safety net
G force Window safety mesh
Sparco hood pins
Tekniq steering wheel with quick release hub
Front and rear tow eyes installed
Wheels and Tires
Turner motorsports wheel studs
3 sets of 14” speed light wheels and tires, two shaved sets, one rain set.
Car 217 is straight and has never sustained any collisions. It is competitively and safely equipped, and ready for a season of reliable and fast racing. $17,500 obo.
Contact Duncan Pearce at 604 761-2277 or email duncan@urbangarage.com
Seat:
Sparco
Suspension:
Engine:
New clutch
Exhaust
Headers
Differential:
Transmission:
Brakes:
MISC:
Safety:
Sparco hood pins
Wheels and Tires
