[For Sale] 2002 OMS GSXR
Kartracer
OMS Sports Racer originally purchased with 04 Carb Yamaha R1
08 GSXR from a used bike - unknown mileage approx 7 hrs in car use
Rilltech wet sump pan
Stainless steel headers
Coolant/oil intercooler
Cockpit widened at shoulder area well braced for torsional rigidity
I am 5' 11" 200# and fit easily
Dual radiators - ducted from front (new mod) 1 alum race radiator and one OEM Rabbit radiator
New front pads - rear pads like new
Cockpit adjustable brake bias
New wheel bearings approx 8 hrs ago
Resealed calipers 2 years ago
Front splitter modified for downforce and rub blocks incl spare set rub blocks
New rear tunnel
Modified wing mount - removable tail without wing removal
Adjustable steering column
Left foot braking only
Hand clutch infront of steering wheel on right - cable to shortened clutch pedal
works like a shifter kart much easier to use than a clutch pedal
Shifter on left
Simple electrical no lift shift up
Cockpit adjustable throttle blipper for down shift
Modified body work for splitter air exit along body sides
Fiesta OBX (?) torsen diff
Penske shocks
Extra set of wheels with mounted rains
CDS panel on steering wheel with data logging
Oil pressure warning light and neutral indicator light
AFFF Firecharger fire system
Transponder - hard wired
PDR100 camera system
PC545 battery and booster battery plug at rear
Crow belts will need rewebbing expire 2020
More pictures here -- Join if you are not already registered https://www.apexspeed.com/forums/showthread.php?90120-2002-OMS-Sports-Racer-GSXR-1000
$8750 OBRO
John Rounds johnr@tricksolutions.com
360 four 77 two 0 eight two
Port Angeles, Wa 98362
