steve_justiss
1984 Mazda RX-7 Race Car
$5500
Reliable, low maintenance race car.
Prepared for the Pacific Northwest ICSCC (Conference) PRO7 class and very close to other spec. Rx-7 classes. SCCA ITA, NASA PTF, Chump Car, Lucky Dog, SOVREN, SVRA.
Clean Washington title.
5 time ICSCC Pro7 champion. Tons of race wins.
Professionally built ICSCC approved roll cage with NASCAR bars on the drivers side.
High impact roll cage padding.
Fresh engine professionally built with new rotor housings and carbon apex seals. Balanced. I put 147 hours on track on my last engine from the same builder and only removed it for an oil leak.
Carburetor prepared as allowed by regulations. Extra jets.
Cold air intake for carb.
Professionally built 5-speed trans.
New 4 puck racing clutch.
Professionally built GSL limited slip differential with rear disk brakes.
Braided stainless steel brake lines.
Calipers race prepped.
Brake air ducts: front 3/side, rear 2/side.
Front and Rear brake bias valves and brake pressure gages.
Exhaust gas temp gage.
Removable steering wheel
Sparco racing seat
7 point Impact Racing harness and Schroth right side/interior net
Window net
Ultra-Shift tach with adjustable shift light
Firecharger 4.6L AFFF fire system.
Fuel Safe 22 gallon fuel cell with internal surge tank
On/off safety switch
Adjustable camber/castor plates
Strut brace
Bump steer spacers
Racing Beat front and rear springs
Tokico Illumina adjustable shocks front and rear.
Adjustable rear sway bar
2.5" exhaust with Magnaflow muffler.
4 sets of wheels
6 good tires
Car cover
Spares Included:
Carb - fresh race preped
Distributor
Alternator
Starter
Front and rear brake systems (master cylinder, calipers, bearings, rotors and pads).
Body parts.
Limited slip differentials
Steering box
Front and rear suspension components
New distributor caps, rotors and plugs
Axles
Rear axle housings
Wheel bearings.
Text or call Steve at 253-691-1883. The car is located near Belfair, WA.
$5500
Sparco racing seat
Window net
Strut brace
Bump steer spacers
4 sets of wheels
6 good tires
Car cover
Spares Included:
Distributor
Alternator
Starter
Body parts.
Steering box
Axles
Rear axle housings
Wheel bearings.
